#674452 06/25/03 11:04 PM
mi5pal Offline OP
I've had my SHO Shop y-pipe for a couple of months, and have enjoyed it until now. While my car idles this vibrating noise seems to resonate from the cat's heat shield. I have checked all the bolts and they're on tight. Just wondering if anybody has experienced a similar problem? If so, how was it remedied?
#674453 06/26/03 12:14 PM
Its probably a resonance sound thing. You can try and change the rubber exhaust hangers to new ones...they might dampen those frequencies. Or, like I did...add another exhaust hanger up front. If you look under the car up near where the original Y came together on the passenger side, you'll see an un-used exhaust hanger that ATX cars use. Go to a muffler shop and have them weld a hanger near there and use a new rubber donut thingie...I did and it helped a lot...
#674454 06/27/03 09:38 PM
Webmaster
Webmaster
If you didn't get it welded, it will work itself loose. Get it welded!
Been there, done that.
-Lance
Lance Kinley CEG Webmaster 95 SE, "Cassandra" 10 years!
#674455 07/02/03 03:40 AM
More than likely it's SHO Shop's piece of trash cat interiors breaking up.
I've seen and heard of this happeneing to many people.
This is what I did:
~pulled off the y-pipe
~shook the cat and confirmed that the "guts" were breaking loose
~used a long handled screwdriver and broke up the rest
~poured out the "guts"
~re-installed y-pipe
Problem was solved.
Capitol CEG Classifieds Make an offer! 2005 GTO IBM - 337hp/336tq
#674456 07/08/03 12:04 AM
mi5pal Offline OP
Thanks guys, I will check all of the recommendations out, I hope it's not the cats coming apart. But I will consider having it welded together, or adding another mount.
