#674171 06/25/03 06:07 PM
I am looking at putting a pair of 6 1/2 components in the front of my tour. I am thinking specifically of kicker rs6c. Has any one on here done this and if they have how hard was it and how does it sound. Thanks
#674172 06/25/03 11:14 PM
someguy just posted a thread about the mdf spacers. He's giving them away for free if u pay shipping. They are adapters to fit those speakers into our stock 6x8 holes.
TPC Northville, MI 2002 - Pitch Black Focus SVT (Red Trim) Steeda Short Ram Intake 5% Tint All Around 98 Contour SE Zetec ATX - *RIP* @ Charity Motors
#674173 06/26/03 12:36 AM
Captain Impound Boy
Captain Impound Boy
I had Soundstream SPL 6.5's in my CSVT
sounded awesome. i just fiberglassed over the stock holes then cut out hte circle.
#674174 06/26/03 12:57 AM
Ive got Boston Pro 6's in my doors with a fiberglass baffle.
99' Silver Frost SVT 18" Racing Hart C2's Fidanza Flywheel SPEC Stage III clutch Torsen Diff. Color matched Headlight covers Ding guards removed B&M Short Shifter Koni's and Ground controls NGK Iridium plugs
#674175 06/26/03 01:21 AM
An MDF baffle is very simple to make. You can either use 1/2 or 3/4 MDF, depending on the height of your speakers. 1/2 is probably better as it will not cause interference w/ the inside of the door panels.
You can use the factory plastic speakers as a template and re-use factory self-tap mounting screws to hold it in place. I highly recommend using some sound damp (dynamat, cascade) around the speaker mounting hole. Also, you will want to seal the baffle to the door w/ some type of gasketing material...no rattles, etc.
If you really want to bring some life and definition to your midbass, use some sounddamp on the inner door skin and put cascade deflex pads behind the speakers over the sound damp. At high volumes, the sound wave from the rear of the cone will bounce against the inside of the door panel and back to the speaker causing muddiness, distortion, etc. The deflex pads will alleviate most of this.
Let me know if you need pixs (I can't post them but maybe you can)
1998 Contour SVT #1007 -------------------------------------- Image Dynamics/Morel/Phoenix Gold/JL Audio/Eclipse/Alumapro The continuing quest for audio perfection...
Moderated by  dnewma04_dup1
