#673383 06/25/03 12:30 AM
Hi New to this site.
My trouble seems to be common here. Low revs in gear but ok in P or N. I have a 95GL 2.0L auto. This is what I've done.
1 changed out plugs.
2 cleaned and changed out the IAC
3 cleaned and changed out the MAF
4 cleaned the TB
5 checked for air leaks can't find any.
6 swapped the PCM with a knowen good one no help.
The car is running very rich. Any help would be great.
Sorry forgot also cleaned injectors.
#673384 06/25/03 02:09 AM
Welcome to CEG!
If you know the car is running rich, make sure vacuum is reaching the fuel pressure regulator. If so, check fuel pressure (about 35psi at idle - not 45). A crushed return line can also raise fuel pressure.
A bad ECT sensor might cause this.
Be sure to change the oil if it smells of gas!
#673385 06/25/03 02:15 AM
O
O
mine did that. change the plug wires
95 Mystique GS Zetec ATX: Dead - Dec 5th, 2003 94 Accord LX 2.2L MTX Non-Vtec. Few bolt ons. 02 Escape XLT 3.0 V6 ATX. This thing has the CD4E in it?! What the hell was ford thinking?
#673386 06/26/03 02:45 AM
Agree - my problem went away changing the original plug wires.
