#60799 05/14/02 01:19 AM
X
xx boy Offline OP
X
I just found out both of my rear springs broke.Any tips on changing springs and how much for after market and OE spring?
#60800 05/14/02 02:42 AM
AFAIK, 98 is under recall, what year is yours?
--alex | 96 GL(sort of) V6 ATX | 98 SE V6 MTX Sport
#60801 05/14/02 05:09 AM
X
xx boy Offline OP
X
It's a 95.I live in salt belt but springs still should not broke like that easily.
#60802 05/14/02 07:00 AM
E
E
You might want to consider changing the struts/mounts while you are in there, especially if yours is a higher mileage car. Maybe check the classifieds or ebay for some used ones?
Corey can get springs, you can find a thread on these, here .
· Jon Miconi
· 96 Contour Zetec ATX
· 80 Ramcharger 360 ATX
· 77 Ramcharger 440 ATX
#60803 05/14/02 12:20 PM
Jontour in Minnesota has the exact same problem on his 95. I'm replacing them with SVT struts and springs this weekend.
The first Blown 3 Liter!
"Drive it till the wheels fall off" -my personal motto!!!!
98.5 T-Red SVT #6180
Many Mods
Buckshot77@aol.com
Owner of 00 #1611 Silver
Totalled on 10/7/01
SVT Parts for Sale
#60804 05/17/02 01:55 PM
X
xx boy Offline OP
X
Can I put svt spings in my 95 se?
#60805 05/17/02 02:17 PM
E
Eli Offline
E
yes but it will ride higher - SVT is heavier 300lbs than other models, and so the springs are beefier. afaik anyway, i just read this a little while ago in the suspension forum, i think.
96 Contour SE, MTX
2 Pioneer 12"s in a bandpass box
2 5x7 Pioneer Plates
2 Stock Speakers
600 watts of blistering radioshack power
#60806 05/26/02 06:19 AM
X
xx boy Offline OP
X
Well beefier springs?!It may be harder to break on non SVT? anyway I've several questions for those have changed your springs or struts youself,how did you break the strut bolt loose?I'm using 1/2 inch wrench with no success,may be heat it up? and what size of socket I should use on the front lower arm(rear)?
Ford has recall for the front springs (from what I read on Alldata.com)but why not the rear?
BTW if anyone has spings for sale email me at Bulebird123@aol.com
#60807 05/26/02 12:01 PM
H
H
As I recall the spring recall was to install a shield to prevent a broken spring from contacting and possibly cutting the tire. It was not to replace springs.
p.s. You'll need Metric size tools.
stock CD on LS, cass on LX
4 wheel discs on LX only
#60808 05/26/02 12:46 PM
E
E
Same thing happened on my 95, it's not all that uncommon, they corrode way too easily. I expect my fronts to need replaced in the next 10k miles.
