Posts: 24 |
Have searched extensively on the waterpump and are well aware of the issues. One thing I noticed is that not many 99 and 2000's have been mentioned. Maybe this is because they have not clocked the mileage yet? Questions: Anyone with a 99 or 2000 have a pump failure? and at what mileage
The people that have replaced it(any year) with the BMG metal impellar pump, any long term reports or any engine temperature differences?
Posts: 1,355 |
Originally posted by GS:
The people that have replaced it(any year) with the BMG metal impellar pump, any long term reports or any engine temperature differences? No problems at all. Engine temp keeps below the half way point. Seemed to run a little cooler if anything.
Simon W. Las Vegas. 96 SE V6 MTX Tereador Red (1st Blown Engine, better be the last!) 1999 SVT Engine SVT Exhaust w/custom DTM Tips and optimized Y-pipe and no Res (thanks to Po-Jay!). LSD Quaife(thanks to Terry!), SCA CAI w/KKM, Grizzly clutch, FMS 9mm wires, Airknights custom short shifter.
"You can only get more rice at one time by ordering Chinese" - Davo7SVT "it's only nuts and bolts" - Terry Haines "Drive it like you stole it" - Me!
Posts: 559 |
99 SVT No Problems - 77K Miles :rolleyes:
99 SVT Black/Tan #1090/2760 82K Miles.......B&M Edge Shifter Mobil1 5-30.....Side Markers Ford Synth MTX # XT-M5-QS Locking Lugs....Cup Holders Black Sail Panels...TH Fix Aluminum Gas Filler Door BS Potenza S-03's KVR Cross Drilled Rotors + Pads Dual Mode Damper - soon Clarion head unit Pioneer 2-ways
Posts: 3,419 |
At some point, Ford switched the OEM pump to the tan (ABS) plastic pump, so the evil black impeller was gone. (Hmmm, they know there is a problem but don't issue a recall because cost is certainly more of a priority than customer satisfaction.) Most of the late model cars probably have the improved pump, so that might explain the lack of problems.
Posts: 1,355 |
Originally posted by PA 3L SVT: At some point, Ford switched the OEM pump to the tan (ABS) plastic pump, so the evil black impeller was gone. (Hmmm, they know there is a problem but don't issue a recall because cost is certainly more of a priority than customer satisfaction.) Most of the late model cars probably have the improved pump, so that might explain the lack of problems. Oh so that's why when I took the WP off the SVT engine I bought to place my Metal one from my SE engine (which replaced the broken one) it was a different color impeller (it was tan), I was wondering about that. dammit, so I could have left it in then! Oh well, better safe then sorry. Anyone need a Water pump...$20????
Posts: 1,083 |
I have a 98.5 with 160 km and no probs.
1998 SE ATX Dual exhaust Body conversion Nakamichi CD-40z HU Sound by Crystal Mobile Powered by a/d/s M860 AMP My Ride
Posts: 294 |
It might actually have something to with MTX\ATX - with ATX you usually on lower RPM's so you might have less stress on waterpump. I replaced mine just to be on a safe side.
Regards, Kirill 98.5 Contour SE Silver Frost (powered by Duratec 2.5L) Nakamichi CD-45Z -> Phoenix Gold XS4300 -> Infinity Kappa 693.3i \_ Blaupunkt ODx694
Posts: 24 |
Its seems that 99's and 2000's dont have the record of pump failures that earlier models do.
Posts: 230 |
I have a 96 V6 auto se and my pump went on the two days ago and I had to chnge it on the spot so I ended up putting the same black plastic thing in there. To bad I didn't know about the one with the metal Impeler for the same price I paid. I had 75,550on my tour.
Posts: 581 |
Originally posted by TonyD: I have a 98.5 with 160 km and no probs. Be very careful. I had about 172 KM on mine and it went. Now I had plans to change it just hadnt done it yet and it went on me.
