#60709 05/13/02 04:47 AM
I
I
Has anyone had troble with thier drivers power door lock? Mine sometimes jams up and won't unlock with the unlock button or with my keyless entry. Its getting really annoying because its happening more often now. If anyone can help me out with it that would be great!
Jerry
97 Contour Sport V6. T-Red, KKM tru rev induction, Ford racing wires, Cooper Cobras GTH, A pillar gauge pods with ford racing gauges, Clifford Matrix alarm, painted red calipers, full bra, premium audio installed,LED's, Ford Racing seat belt pads. It's my baby!!! I love to pull up to a honda or a VW and blow their "fast and furious" doors off. Imports can suck my american exhaust!!!
#60710 05/13/02 02:36 PM
Not real sure if it is the same basic mechanism as the early 90's, but I know that a number of FoMoCo products ate lock modules like candy. If the design has changed in the last decade, then apologies in advance for the rabit trail...
I finally decided on the Mustang that it was easier not to replace the lock than to tear the door apart to get at it.
When they both failed, it was a gradual thing. I believe it was a combination of design and binding from dirt that contributed to the problems.
#60711 05/13/02 03:50 PM
I
I
What do you think I should do? Should I get a whole new lock or just the module? Thanks for the info!
Jerry
#60712 05/14/02 02:59 AM
Like I said...don't have a 'tour, and I cannot speak definitively about the locks on them. I was hoping someone else might jump on the thought I tossed out there.
However and with that caveat, if the lock works properly using the actual key, then it suggests to me that the power lock motor crapped out on you. Although my last three vehicles have all been FoMoCo products with power locks, the Mustang is the only one that had lock issues. The power mechanism was held to the door with (IIRC) two pop rivets. There was a rod attached to the actuator that then popped loose that would have to be placed in the new actuator assembly and then pop riveted back into place. The door panel had to come off in order to change it out, and the labor was actually more than the actuator. Even with the newer cars having more of the generic modules controlling a lot of functions, power locks are still most likely using a very similar cheap-a$$ actuator. If I can dig out the manual from the '98 Ranger, I will see what they showed for the actuators and compare with the '90 Mustang manual (don't have either vehicle, but I think I still have the shop manuals around the house somewhere).
If my theory holds true, then the real question comes down to how much the convenience of power locks is worth to you or how mechanically inclined you are when it comes to tearing into the door.
