Cabin filter is relatively easy to change. It should cost you around $15-20.
Both they Haynes and Chiltons manuals are a little off on this procedure. If you decide to DIY, you DON'T need to remove the wiper, and it is on the passenger side.
96 Contour SE
Duratec V6 24-valve 2.5L ATX
108,000 mi.
Replaced: crankshaft w/ DMD, EGR valve (clogged), EVR, DPFE, PCV valve, evap emissions hose & tube (cracked), window regulator (broken), LH & RH PCV tubes, UIM gasket (leak), ignition coil
