#60637 05/12/02 04:09 AM
I've had this problem for a while now, and it's getting really annoying.
While driving (under a small load) or idleing the car feels like it's misfiring, and therefore bucks slightly. It doesn't happen constantly, just when it's in lower revs (less than 2500).
i decided to reset the computer, to see if it helped. It worked for a bit, but then came back. The car threw a CEL.
after reseting the computer again, the car has started to do the bucking more often. I checked plug wires (looks fine) and after inspecting a plug from each bank, i noticed it looks like the second bank is running hot (lean?).
should i see if cleaning the KKM will help?
is it a tranny problem, electrical, etc.?
any help is appreciated
96 Mystique "Spree" Duratec ATX
"They have the Internet on computers, now?"
#60638 05/12/02 05:34 AM
dwh Offline
Do you have double platinum plugs? I am told that our "waste spark" ignition tends to wear out every thing but the double platinums in the rear bank. If you are using single platinums, or something else, I would try switching to the doubles. It might cure the problem.
95 mystique LS, High Output Cougar S (SVT) 2.5L engine & MTX75
#60639 05/12/02 05:39 AM
If you don't like how the spark plugs look, change them.
If you say you're KKM looks dirty, then clean it.
If you're car is setting a CEL then I'd like to suggest you have it checked out since that will likely lead you to the problem.
"careful man, there's a beverage here."
e-mail: boseraq@hotmail.com
aol IM: madhat1412
