Posts: 68 |
Mine did it for a while and then I reset my computer and it stopped for about a month. Just started up yesterday again. Push in the clutch and the rpms would raise from 2500 to 3000 and sit for about 10 sec. Had the fuel pump replaced about 2 wks ago from sputtering under high rpm. I did the th fix using a 3/16" hole and the car runs beautifully now. Hope this helps being that is sounds like the same problem.
Posts: 160 |
Fuel pump ehh? This is getting worse and worse... I just have 2 questions though... How much? & Where is it? I have a feeling that its not cheap and Im hoping its not in the tank. Please, someone give me some good news...
Kamil
99 SVT ~ "Black Beauty" #2362 of 2760 DOB: 7/28/99
So far... -20% tint w/ front tint strip -Ding guards removed -Fog light mod -Alpine CDA-7875 -2 MTX T6000 12's -MTX Thunder4202 amp -FMS wires w/ Bosch +4's -Mobil 1 ATX
Posts: 68 |
I have ESP but the invoice says the parts were 242.38 and if i am not mistaking the pump is located on top of the tank. Was told you can get to it from back seat or trunk.(not sure though, just here say maybe somebody from the forums can help on that).
Posts: 3,419 |
Originally posted by cfcsvt: I have ESP but the invoice says the parts were 242.38 and if i am not mistaking the pump is located on top of the tank. Was told you can get to it from back seat or trunk.(not sure though, just here say maybe somebody from the forums can help on that). Fuel pump is definitely on the bottom of the tank.
Posts: 586 |
My car has done this off and on since day 1. It will act up for 2 or 3 days and then it will go away. Probably happens about 2 or 3 times a year. It will not happen in the winter, usually when it is warm and humid outside. It pi$$es me off, but I guess it is a feature. When it happens I can "idle" at 50 MPH in 5th gear!!!!!
Posts: 1,083 |
Originally posted by SVTouring: Believe me...I did everything on the scheduled mileage. Plugs, wires, fuel filter, cleaned throttle body(didnt feel any difference though), coolant flush, tranny fluid. Thats all I could think of at the moment. It sucks that I care about it so much and its gotta run like sh*t.
Get the injectors flushed professionaly. Most any reputable shop should be able to find the problem for about 1-2 hours labour. Much cheaper and smarter than just swapping everything out. I learned this the hard way with my Impulse!
1998 SE ATX Dual exhaust Body conversion Nakamichi CD-40z HU Sound by Crystal Mobile Powered by a/d/s M860 AMP My Ride
Posts: 68 |
Actually I found out today that the fuel pump is on the top, you have to fold down the back seat and there is a grommet that you remove, and it gives you access to the pump and sending unit.
