I took my 98.5 Mystique LS/auto for a oil/coolant/transmission fluid change today. I have 59,000 miles on the car.
The service advisor at the neighborhood service center noticed that the serpentine belt had cuts and advised me to replace them.
He quoted me a price on the belt at $57.78 and labor at 0.7 hours for $45.49. The labor fee sounded reasonable, but the price on the belt seemed high- based on web pricing searches.
As for the water pump, I'm getting worried about failing and wanted to replace it. Again, he quoted a price of $99.90 (I asked if the pump had metal impellars) and labor for 1.5 hours at $97.48
Any suggestions? Should I buy the parts and have them install it? Or should I just shut up and go with their estimates?
OEM belt is around $20, metal w/p at Autozone is $70.
Don't let them shaft you on the parts. Labor ??? DIY !! There are plenty enough topics/how-tos to walk you through it plus the gurus, I'm sure will answer any other q's.
Regards...
'98 Mystique LS V6 MTX
"Unprofessional driver, wide open course."
#9 - Hitting .400 for ever
"Wake up the damn Bambino; I'll drill him in the ass." -- Pedro Martinez
"The MTX75 was not designed to be a drag racing transmission" -- Terry Haines
I had the dealer change my serpentine belt at 60,000. For my Zetec the belt was $29.78 plus $29.50 for labor for a total of $59.28.
If you have the Duratech the belt could be more, plus access with the V6 may take longer.
- Jim
'96 Mystique GS, Ztech - ATX,
with CD changer, Sylvania Cool Blues, sunroof, keyless entry, and 9mm blue wires
i'd look around at a few places quickly to find a better price if u dont want to do the work....i paid 77 bucks total to have my serp belt changed and was quoted low as 60...i went for the more expensive repair tho because i trusted that place more than the other...i was expecting to pay maybe 100 or more but several people on this site i believe got the work done pretty cheap
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!!
are my dodgers for real????
9
9
I know someone with an svt who just had those done. The dealer charged almost $600 for the pump, belts, labor, and coolant flush/fill!
If you can do it yourself otherwise find a good private shop...
