#60606 05/11/02 09:34 PM
Recently, I have been having a problem with slippage. To describe it, I will give an example. EXAMPLE: When on the highway, I need to speed up and pass someone. The RPM's go up but the car does not speed up, after a few seconds, the RPM's then go back down and then the car starts to get going. Any help would be appreciated. Thanks.
Brian Pinkerton
99' Silver Frost SVT
#1939/2760 Born 19 April 99
Current mods
17 Inch Enkie RS6 Wheels wrapped in Kumhos, Knauberized doors, LoTek A Pillar gauge pod, with oil pressure so far, NP-Tuning Intake, Titanium metallic tint, resonator removed, Bullit fuel door, Quaife, UR Stage 2 Clutch, Fidanza flywheel
#60607 05/11/02 09:50 PM
Time for a new clutch. Definitely symptoms of a slipping clutch are what you described.
FWIW I recommend the RAM HD OEM replacement if you're going with a new one.
Rick
The first Blown 3 Liter!
"Drive it till the wheels fall off" -my personal motto!!!!
98.5 T-Red SVT #6180
Many Mods
Buckshot77@aol.com
Owner of 00 #1611 Silver
Totalled on 10/7/01
SVT Parts for Sale
#60608 05/12/02 09:08 PM
My car has the same exact problem!!! i have a 95 mystique and i am getting a used tranny put in....
#60609 05/12/02 10:26 PM
The above diagnosis was for a manual trans car. If yours is a manual trans and someone is installing another trans to solve the problem something is wrong. Manual transmissions do not slip.
Jim Johnson
98 SVT
