#669393 06/20/03 07:56 AM
Rubes Offline OP
How do you replace the bottom grill to install mesh. And how do you install mesh to the bottom grill. Not THE EMBLEM GRILL.
Also, can the grill on the back of my 98 svt contour be replaced? how?
1998 Black Contour SVT Pioneer premium speaker system 18 in Yokohama w/ denzos Limo tints
#669394 06/20/03 12:18 PM
O-k Rubes...with all your questions, you are about to get hammered by the veterans on here. Everything you've asked can be found by taking time this weekend and going back thru previous posts. Just go to the bottom, click on to view the past 6 months of posts..and read. See...since all of this has already been beaten to death and answered in deatil, the responses you'll get now will be short and trite. You'll gain a lot more by reading...
#669395 06/20/03 12:49 PM
Here's your answer.
'03 Saab 9-5 Aero
#669396 06/20/03 04:53 PM
SEARCH NAZI's!!!!!!!
Jeff Silva E0 Contour SVT Silver -STEEDA PEDALS -K&N Drop In -Ford Racing Wires (w/Bosch +2's) -Cleared Headlights -Yokohama AVS ES100's -Alpine CDA7893 w/MBQuartz -EUROLITE 9006/893
#669397 06/21/03 05:43 PM
my search has never worked that good on this board. I can only get one page of results, if i click next page it goes to a screen that says no matching results.
98 SVT #1652 of 6535 My SVT "If everything seems to be going well, you obviously don't know what the hell is going on."
#669398 06/21/03 08:24 PM
R_G Offline
Try "Archives"
#669399 06/23/03 03:22 AM
Yes...search Nazi's indeed.
Rubes, buy a set of ramps w/ the extenders. They'll pay for themselves. Trust me.
Once you get the car up on the ramps (front 1st) you'll see where there is a plastic cover (splash guard) that runs from side to side under the front of the car.
I think it's held on with like 12 hex head screws. After you take that off look to see where the lower grill is held on with a bunch of little metal clips.
Pry these off with a screwdriver or a pair of pliers. Now carefully slide the grill out. There are air damns on either side of the grill
that are a royal pain in the azz. You may need to remove them 1st to get the grill out. The lower grill isn't easy (read: it doesn't just fall out) to remove.
But it shouldn't take you more than 10 -15 min start to finish.
The rear grill...back the car onto the ramps...comes out by prying off the same type of clips as the lower front grill. Then it will practically fall out.
No more than 5 minutes start to finish there.
Carefull though...once you start modding, there's no turning back. You'll be a mod junkie!
Enjoy.
'98 SVT Contour #897:Mods= Intake, exhaust, suspension, & aesthetics www.community.webshots.com/user/rob98csvt897.
