#60531 05/10/02 10:06 PM
To all that can help~
I have been getting the code for EGR Valv insuficient flow, so I replace my EGR Valve. The CEL stays off for 5 days and is now back. What else could be the problem! I am going to Windsor next week, and I don want any car problems at all!
Thanks in Advance
Chris
Columbus Ohio
1998 SVT Contour
Silver/Midnight Blue
1673 of 6535
00' SVT Rims
KKM Sill Protectors
Mobil 1 5w30
K&N Air Filter
Mobil 1 badge(from the cobra R)
50% tint
~100,000 miles
#60532 05/10/02 11:35 PM
Insufficient flow is usually caused by EGR passages in the intake manifold being plugged up. The most common place is right behid the throttle body. If you remove the throttle body, the passage will be exposed and you should be able to see what is needed to clean it.
Jim Johnson
98 SVT
#60533 05/10/02 11:42 PM
1)DPFE tubes off or leaking 2)Bad DPFE sensor 3)Blocked egr tube 4)Lite-off cat 'meltdown....
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
#60534 05/10/02 11:47 PM
Besides the above, it could also be a bad EVR (EGR Voltage Regulator).
I don't think that you need to worry too much about the P401. It basically means that you are spewing emissions into our atmosphere at a higher rate than normal. Get it fixed at your convenience.
1996 Contour SE Sedan 4D (Royal Blue)
Duratec V6 2.5L 24-valve DOHC
Automatic
75,000 miles
No Mods (unless you call the DMD a mod)
Replaced EGR valve (gunked up), EVR (EGR VR), PCV valve, and evaporative emissions hose (cracked).
#60535 05/10/02 11:48 PM
What is that???
Automatic
75,000 miles
#60536 05/11/02 01:23 AM
H
H
Originally posted by G Pappas:
...Besides the above, it could also be a bad EVR (EGR Voltage Regulator).
I believe EVR means EGR Vacuum Regulator. It's really a solenoid valve (open or closed) that regulates vacuum to EGR valve.
While I would generally agree with the above statement, in view of your destination I would say get it fixed sooner rather than later. smile
p.s. Seriously, I think first step should be reset PCM and see if or when CEL next appears.
p.p.s. Why don't you delete 6:04pm post and clean up the board.
stock CD on LS, cass on LX
4 wheel discs on LX only
