Heres the thing. I just pulled a P0135, P0141, P0155, and P0161 codes. That's O2 sensor heater circuit malfunction on all the sensors. Can some one please give my a logical explanation on what could cause the problem on all four sensors.
I forgot to say I checked the fuse, but I did it with on ohm meter with it still in. But you convinced me to check it a gain and what do you know there was crap on the blade causing a bad circuit which I couldn't tell with the tester because I didn't pull it out. THANKS JEFF!!!!!!!
