#666820 06/17/03 10:41 PM
F
fingas Offline OP
F
I just noticed today that if i turn on the rear defrost while i am at a redlight my car seems to idle a little ruff and sounds like it is suddenly under more of a load. Is this normal.
1996 Zetec MTX NO Mods it's only a matter of money now though.
#666821 06/18/03 02:09 AM
not usre if it is good or not, I have noticed the idle go up on my car when i turn the rear defroster on
but then again I get the head lights dimming when I put the clutch in to stop, and I hear a idle difference, not rough, when closing the windows so it might be fine
#666822 06/20/03 08:42 PM
Both you all have similar problems ie; your rear defrost/power windows and headlights coming on and making your engines idle differently/lower. While the Zetec 2.0 liter is a great motor, at idle it's probably only making a couple horsepower. When you turn on a large electrical drain item like rear defrosts, etc it puts a drain on the electrical system and the alternator pulls the engine rpms down a little. I would definitely check the condition of your battery or see if maybe your battery has the correct amperage rating for your car. But it's nothing to worry about, it's fairly normal. Hope this helps, Ken
Ken, 99 Silver Frost SE Zetec Atx, polished alloys, Kumho's, Pioneer hi power CD/AM/FM. Factory spoiler (added) Audi side lites, Borla stainless steel muff. Stolen, recovered in pieces. Looking for another Tour, preferably V6, 5 speed.
#666823 06/22/03 11:22 PM
I believe that if all is working correctly, the idle should come up a bit when the rear defroster, lights, etc are
turned on. The computer should be adjusting the idle to compensate for the alternator drag.
At least mine does.
- Jim Our yardbirds: Belvedere, our '96 Jeep Cherokee, 4.0L ATX, 85,000 and going strong Spencer, our '03 Chrysler PT Crusier, 2.4L ATX, 28,000 and just getting started
