Between what I read in the old post and what you are saying warmonger, I should just stick to the 2.5 heads since I have no plans to go with turbo or supercharger?
Kinger I know you deal with a shop that does head work. Have you ever milled a 3L head to see if you can get the compression ratio back up and still have the proper clearance between the pistons and valves?
98 SE Sport. custom catback, Intrax springs, 3L, 3L valves, APEXi S-AFC, 24# injectors.
Other cars:
72 Challenger 360 motor 727 trans (used for parts)
73 Challenger 340 motor 727 trans 15.60 1/4 with bad miss and clogged fuel filter.
