#664303 06/15/03 04:01 PM
I have a CEL for the EGR valve, the problem is that i had it replaced 2 months ago. The CEL is always on, what else should I check for. Also if i give it 50% throttle in 1st gear when the secondaries open the is a hesitation and then it pulls. Any advice would be good because this car does not feel right at all.
-Bassani exhaust *Track #'s* -Sho Shop intake 14.986@92.16 -CTA inlet pipe -MSDS headers w/ Y-pipe -Ground Control Coilovers -Koni Adjustable Struts - Quaife, fidanza, spec 3 -DMD -Apexi S-AFC
#664304 06/15/03 04:27 PM
what kind of trouble shooting did you do when you got the check engine light for the EGR valve(possible a P0401) code?? you dont just change out parts as it is only in the EGR system... did the light ever go out and stay out?????
#664305 06/16/03 05:44 PM
Did you by any chance check the DPFE sensor?
(Gas pressure differential sensor.)
I know Ford re-engineered it and that was my problem.
I was getting ERG and O2 codes as well.
Also check for a leak in all vacum lines and that they are on properly.
PCV hose is usually the problem hose.
1996 2.5LT V6 Contour ATX My Tour+help/info pics E0 rims, Gutted Pre-Cats,CTA Custom Exhaust & Intake, Diablo Chip.
