Posts: 118 |
I have seen some heated mirrors on ebay. Where would be the on off switch for it? Has anyone installed these before?
Yankeyspeed: American power and ingenuity
95 SE -Stock enough to be overlooked,
Quick enough to hold it own.
Now driving a 2001 PT Cruiser
Posts: 1,840 |
They're wired into the rear window defroster switch so they come on when you turn on the rear defroster...
Posts: 186 |
I thought heated mirrors were standard on '95 Contours anyway?
Tom
98 LX (Zetec/ATX)
Posts: 4,220 |
According to the homepage, they were an option through 97, then were "no longer an option". I assume that means they were standard in 97 and beyond.
But if my '97 has heated mirrors then they truly suck.
2003 Mazda6s 3.0L MTX
Webpage
2004 Mazda3s 2.3L ATX
Posts: 3,632 |
Originally posted by sigma: According to the homepage, they were an option through 97, then were "no longer an option". I assume that means they were standard in 97 and beyond.
I think that means they were no longer ANY heated mirrors.
"Cobb - It's not just for corn anymore!"
Posts: 4,220 |
Yes, it could mean that, but I always thought that the later year LXs and SVTs at the very least had heated mirrors...
Webpage
Posts: 1,541 |
1998+ Contiques DO NOT have heated mirrors from the factory. Check the harness behind the mirror now, if you have power mirrors. If there are 5 female pins on the connector coming out of the door, the mirrors will be plug and play (I still had the correct fuse on my 98, even though the manual says "NOT USED").
FWIW, I love the heated mirrors on misty or rainy days - clears the mirrors right off.
Posts: 118 |
Posts: 267 |
so are you saying that my factory 98 se mirrors are equipped just not kiiked up? if so then holy crap but i doubt it....
Works on contingency, no money down.....oh wait let me change a few things....Works on Contingency? NO, Money Down!!!!
98 Se in the works....
Looking for,
18'rs-6 or RS-5's SVT rear
FOUND!!!
SVT front (thanks SVTCuervo)
Posts: 1,541 |
If you have 5 pins on the connector, they are ready to go awaiting a transplant of the motor (for the harness containing wiring for the motor AND the heaters) and the heated glass. I know, because I recontented heated mirrors on my car built April 1997 (E0/98 SVT). They come right on when I hit the rear defrost button.
