In the Ford Technical Service Publication for the 1996 Contour, P0306 is actually cylinder #6.
Possible causes:
-- Ignition System. -- Fuel Injectors. -- Fuel Pressure. -- Evaporative System. -- Canister Purge. -- Base Engine. -- Running out of fuel.
The first thing it asks is if the car has recently run out of fuel.
If the car has not run out of fuel, it asks if there are any other codes present. Since there are in your case, it says to disregard the misfire at this time and address the other CELs.
1996 Contour SE Sedan 4D (Royal Blue) Duratec V6 2.5L 24-valve DOHC Automatic 75,000 miles No Mods (unless you call the DMD a mod) Replaced EGR valve (gunked up), EVR (EGR VR), PCV valve, and evaporative emissions hose (cracked).
