Posts: 7 |
hi all:
Mercury Mystique 96 2.0L
I need some help on a steady CEL error code = 0171 System too lean Bank 1
Any remedies ?? or does it need further testing. I would appreciate if someone could point me in right direction.
Also, how do you reset the CEL ? Can you just disconnect battery and push brake pedal 10-15 s to completely drain current in circuit, or do I need to go to dealer.
thanks, Hugues -
Posts: 311 |
I wouldn't worry too much if the car is running okay. As far as resetting the CEL, disconnect the battery for 15 mins, then drive it at low speeds for a while after. there is a complete 're-boot' proceedure available at Blue Oval, but I don't think it's completely nessesary. The car will recalibrate quickly on it's own. If the light comes back, disregard my comments and ask someone who knows more than I do about coding.
1998 Contour Sport V6, Black *Cold air induction *Powdercoated intake manifold (more powdercoating coming soon) *Blue headlights, foggies, and signals (no reflectors) *CEG stickers & removed door moldings -------------------------------- 1994 Ford Aspire 4-door, looks like a big egg *64 hp 4-cyl *5 speed *"13 steel rims with go-cart tires *74 mph top speed *I'm going to auto-x the thing (but not compete)
Posts: 237 |
The following is from the Ford Technical Service Publication CD:
Diagnostic Trouble Codes (DTCs) P0171 bank (1) (cylinder #1) and DTC P0174 bank (2) indicate the fuel/air ratio is too lean. The fuel adaptive system is at the rich correction limit.
Possible causes:
Fuel system
-- Excessive fuel pressure. -- Leaking fuel injector(s). -- Leaking fuel pressure regulator. -- Low fuel pressure. -- Contaminated injector(s)
Induction system
-- Air leaks after the MAF. -- Vacuum leaks. -- Restricted air inlet. -- PCV system. -- Fuel purge system. -- Improperly seated dip stick.
EGR
-- leaking gasket. -- Stuck open EGR valve. -- Leaking diaphragm.
Base engine
-- Oil overfill. -- Cam timing. -- Cylinder compression. -- Exhaust leaks before or near the HO2S's.
* Check air intake for leaks, obstructions and damage. * Check air filter, air filter housing for blockage. * Verify integrity of the PCV system. * Check for vacuum leaks.
1996 Contour SE Sedan 4D (Royal Blue) Duratec V6 2.5L 24-valve DOHC Automatic 75,000 miles No Mods (unless you call the DMD a mod) Replaced EGR valve (gunked up), EVR (EGR VR), PCV valve, and evaporative emissions hose (cracked).
Posts: 1,040 |
Pulling fuse 11 in engine compartment fuse box for a couple of minutes resets CEL.
Posts: 7 |
Thank you all for your input. After I had posted, I found quite a few posts about the subject. Sorry about that.
In any case, I replaced the pre-cat o2 sensor and cleaned up the MAF sensor. The CEL has not come up yet after 20 miles, so maybe it is fixed.
Hugues -
