Page 2 of 2 1 2
H
H
Old British folk tune from Robin Hood's day Greensleeves, calming music for your next task. smile
stock CD on LS, cass on LX
4 wheel discs on LX only
As far as I know there is no Ford part number for the little green sleeve. I found some in the Parts Express catalog. Parts Express is an electronics supply house. You can find them on line at www.partsexpress.com but I needed a hard copy catalog to find the sleeves. They offer several colors and two different sizes and are packaged in quantities of ten. Even buying ten at a time, they are still very cheap.
Jim Johnson
98 SVT
Just in case someone else needs it, we found the part numbers for the green bulb covers at Parts Express (see above post).
070-082 .12" diameter green bulb cover sleeve
070-092 .20" diameter green bulb cover sleeve
If I read the catalog correctly the price is $1.70 for a package of ten.
Anyone want to measure the diamer of the bulb so we can see which diameter is needed?
Jim Johnson
98 SVT
hi. Thanks for the info. I measured the bulb and and the diameter is exactly .20 inches. I just ordered a pack of 10. Thanks again.
6
6
Thanks on the green sleeve part #
Mike
I have a dream, and that is a 69 Boss 302 with Jules Asner in it.
Current - 2002 Chevy Silverado
Former - 98 SVT E0 T-Red 4/4/97 #173 of 6535(so long girl, you'll be missed)
i found that using a lighter works well to illuminate the clock after dark wink
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!!
are my dodgers for real????
Sorry to resurrect an old topic, but... Does anyone have the part number for the clock light bulb/holder combo? The parts monkey at my friendly local Ford dealer tells me they only sell the clock module.
TIA,
Garrick
Garrick
Silver E0, #3895 of 6535, built 10/2/97
She's stock. Why mess with a good thing? laugh
I had that part number on a business card in my wallet for a long time but I finally threw it out. You should be able to find it with a search since I remember posting the part number a few times in the past.
You might also try calling another dealer and finding someone that is more willing to help you find it. It uses the same part for all clocks (as long as they used a clock) starting with the 95. It might help to look it up as a 95.
Jim Johnson
98 SVT
My bulb went out in my clock, replaced it with a bulb from the third brake lamp smile was a real PITA to chance because I dont have tilt wheel frown oh well...I got it done, now all I need to do is go to the dealer and get another 3rd brake lamp bulb...
YOUNGEST CEG MEMBER smile
1995 Mystique LS V6 ATX, Moonlight Blue Clearcoat Metallic, Atlantis blue cloth. Fully loaded except leather, sunroof, and CD.
1990 Pontiac 6000 S/E AWD
Brilliant White with 2-tone Gray leather, fully loaded
Page 2 of 2 1 2
