W
wallee Offline OP
W
Noticed a red puddle under my car today. I haven't had much time to look into it yet but I know it's a steering fluid leak but only when it's running. It's leaking from roughly the middle area of the rack. I haven't gotten right under the car yet so I'm not sure exactly where it's leaking from.
Anybody had any problems in this area? Is this a common problem with our cars?
The car had a new rack put in just before I bought it so hopefully that's not the problem.
Any input or suggestions?
96 Teal Contour Zetec ATX 96K's
How long ago did you buy it and can you take it back to have them check? I would say, middle of the rack may be a loose fitting, check your boots too and make sure nothing is leaking there....
Rich
'04 Ecotec Cavi 140hp/150tq Fabbed intake. Header Coming, DRL's disabled, X-Drilled/slotted rotors coming....Man you really are fast. You were hauling a$$ when I passed you RB&LB causing problems in Huntsville
