Originally posted by ARJoel:
The fuse fusing my 4-way flashers, cruise control and horn keeps blowing. I have replaced it 3 times and it keeps blowing. Did anyone else have this problem? How can i fix it? By the way the vehicle is a 1998 contour.
There is an open circuit somewhere within what you described. Check your wiring around your steering wheel and fuse location. Also, make sure you are using the correct amperage fuses.
