Posts: 1,451 |
Originally posted by SVTpyr8: is that a ru3530 filter?
No, it's the RU1785
Vinny 2000 T-RED CSVT
MODS: 18" REV model 2 ST200 struts/Roush springs
CTA intake Pipe/K&N Filter
Dtec Heatshield
Optimized TB
True Duals w/ magnaflow mufflers/resonators
Posts: 29 |
If you use the rvm intake that's on e-bay for our cars and buy the d-tec heatshield for it along with the hole in the hood for the scoop you'll be fine.
black 98 svt
power 1 mufflers w/resonator removed
jvc headunit
rear reflector and front grille painted black
ding guards removed
side badges replaced w/apc oval lights
born on sept. 3rd of 97' #3,382 of 6,535
Posts: 10 |
what's the different between ru-1785 and ru-3530? which one is better?
Posts: 1,451 |
Originally posted by eric_svt: what's the different between ru-1785 and ru-3530? which one is better?
Different size and shape. 1785- 5 in. diameter, 8 1/2in. long. BTW this is the filter I'm talking about  3530- This filter is tapered, 4 3/8 in. to 5 3/8 in. diameter and it's 7 in. long.
Couldn't tell you which one is better but I'm happy with mine.
Dtec Heatshield
Optimized TB
Posts: 1,322 |
Originally posted by svt contour 98: If you use the rvm intake that's on e-bay for our cars and buy the d-tec heatshield for it along with the hole in the hood for the scoop you'll be fine.
RVM is junk, bought one for my SE. Poor craftsmanship, cheap hoses, clamps. The filter is small, the MAF adaptor is small, the intake pipe is small and paper thin! It has been removed from my car and installed in the trash!
Search around a little, there may be a few posts re; intakes, filters, heat shields, induction.
1999 Toreador Red SVT, DOB 4/22/99, 2005 Of 2760.
"Many posted questions are answered by farm boys"
Posts: 1,746 |
I havent heard any good things about the RVM intake. I'd stay away from it.
Posts: 837 |
Originally posted by Pienstars: Originally posted by eric_svt: what's the different between ru-1785 and ru-3530? which one is better?
Anyone have pics of the 3530 on the car?
CSVT
Feels Like Heaven
Goes Like Hell
Profile
Posts: 1,322 |
Originally posted by Bridge: Originally posted by Pienstars: Originally posted by eric_svt: what's the different between ru-1785 and ru-3530? which one is better?
DemonSVT
Posts: 9,602 |
Originally posted by Marky: Originally posted by Bridge: Anyone have pics of the 3530 on the car?
DemonSVT
Nope. Mine's not an RU-3530, but that's another story.
However the RU-3530 is the best choice for a 3.5" MAF adapter though.
There is no real performance benefit in getting a filter that is over 2x the required effective filtering area. An RU-3530 will sustain any NA Duratec without a problem.
I also prefer the tapered cone filter because it helps keep it off the inner fender (I.E. losing filter area) and also allows incoming air from the fender draw/air hose to pass more evenly across a greater portion of the filter.
Also more of the filtering area is used and used more effectively due to it's shape. As the distance from the MAF opening gets farther away the draw of air is weaker so narrowing the filter helps even out this effect. Pulling across a greater area and more evenly is more effecient.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 34 |
I thought of something....if someone could design a hood that has something like a luver on each side that would direct air directly into the top of that box you would get a true cold air intake! And the faster you go the more air goes in there!! What do you think? Somebody who's good with photoshop could give us a picture of this maybe?
