Posts: 3 |
how do I get to the sparkplugs in my 1995 ford contour se? is it just a matter of taking off the top like it looks or am i going to run into problems as soon as I start?
Posts: 667 |
You don't need to take off the upper intake manifold. Check here for the How-To on replacing spark plugs.
96 Contour SE
Duratec V6 24-valve 2.5L ATX
108,000 mi.
Replaced: crankshaft w/ DMD, EGR valve (clogged), EVR, DPFE, PCV valve, evap emissions hose & tube (cracked), window regulator (broken), LH & RH PCV tubes, UIM gasket (leak), ignition coil
Posts: 1,322 |
You do not need to remove the coil pack or disconnect the wires from the coil. I removed the IMRC only. There is an excellent post (w/pics) that shows exactly how to do your plugs. All you need is 3/8 drive ratchet, a long (I used a 10") extension, a plug socket and a little duct tape. Tape the socket to the extension. Gap all the plugs before you start, its a 15 minute job. Search around a little youll find the post I'm refering to.
1999 Toreador Red SVT, DOB 4/22/99, 2005 Of 2760.
"Many posted questions are answered by farm boys"
Posts: 4,639 |
r plug sockets a universal fitment part or do we need a specific one for our plugs
Hugo AIM:omegazodiac
Posts: 667 |
Originally posted by Marky: There is an excellent post (w/pics) that shows exactly how to do your plugs.
Here is the post..
96 Contour SE
108,000 mi.
Posts: 160 |
Originally posted by hmouta: r plug sockets a universal fitment part or do we need a specific one for our plugs
They fit the standard, late model 5/8" sparkplug socket. The 2 most difficult parts of changing the plugs were: 1) getting the plug connectors (at least on the stock wires) past the UIM, ya gotta rotate them until the 4 centering ears on the body of the connector are oriented 45 deg to the C/L of the engine to slip them past the UIM, and 2) you're working blind on the firewall side of the engine so you need to feel your way into the plug wells. The front plugs are a breeze. I didn't remove the coil pack either.
Kurt
'95 Contour SE, MTX, Champagne
'03 EB Expedition, Med Wedgewood Blue
Posts: 3,867 |
Try it with the coil pack in place, but I had to move it. I just couldn't get my hand in there to remove the boots and get any kind of leverage on it without moving it out of the way. If you do have to remove the pack, it's not a big deal.
Function before fashion.
'96 Contour SE
Posts: 4,639 |
Posts: 1,960 |
How tall are you guys ??  I've seen so many posts from people that say they can't see/reach/feel/find the rear plugs. I'm 6'3" and I'm able to see down the plug well, even the rear one close to the center of the car. I was able to take a good look at the piston heads when I last had the plugs out.
Bless our servicemen & women overseas.
L.Cpl Ian Malone, 1st Battalion Irish Guards, R.I.P.
Posts: 160 |
I'm 6'2" and I can't see the back ones without using a mirror below the windshield cowl and a bright light. The front edge of the windshield cowl blocks my view from above.
Do you gots eyes whut extends out on stalks???
Kurt
