#60013 05/04/02 06:21 AM
Red Offline OP
My daughters cel came on the other day. when tested the code readout was the egr low flow.
Cleared the light, ok for 2 days and then on again.
Code the second time was egr low flow and then egr flow high.
Cleared light again. ok for 2 days on again.
96 2.0 zetec vibrator.
Black 96 gl
mostly unchanged
except for the urge to have it crushed
#60014 05/04/02 01:17 PM
...when tested the code readout was the egr low flow.
I assume that you received code P0401. If you did, then basically your EGR (exhaust gas recirculation) system seems to be having problems. This seems to be common on Contours.
According to the Ford service CD, this can be caused by the following:
-- EGR valve stuck closed or iced.
-- EGR valve diaphragm leaks.
-- EGR valve or flow path restricted.
-- EGR vacuum hose off, plugged or leaks.
-- VPWR circuit open to EGR Vacuum Regulator (EGR V.R.) solenoid.
-- EVR circuit to PCM open.
-- EVR circuit to PCM shorted to PWR.
-- Differential Pressure Feedback EGR (D.P.F. EGR) sensor pressure hoses both off.
-- D.P.F. EGR sensor pressure hoses reversed.
-- D.P.F. EGR sensor VREF circuit open.
-- Downstream pressure hose off.
-- Downstream pressure hose plugged.
-- Damaged orifice tube assembly.
-- Damaged EGR V.R. solenoid.
-- Damaged D.P.F. EGR sensor.
-- Damaged PCM.
Check the EGR and connecting tubes first. Check the tubes for blockage and vacuum leaks.
The reason that the light stays off for 2 days is because of the way a CEL (check engine light) is stored. A CEL is stored as follows:
For the fuel system a CEL is stored if a malfunction results during 2 out of 3 consecutive "drive cycles". A "driving cycle" is engine startup and shut down.
In other words, once you reset the code it will only be set again if the problem happens during 2 out of 3 "drive cycles".
1996 Contour SE Sedan 4D (Royal Blue)
Duratec V6 2.5L 24-valve DOHC
Automatic
75,000 miles
No Mods (unless you call the DMD a mod)
Replaced EGR valve (gunked up), EVR (EGR VR), PCV valve, and evaporative emissions hose (cracked).
