The subject line says it all - are the ATX trannies the same between the v6 and 4 cyl cars? Are they interchangable? I may be able to buy a '98 4cyl GL ATX dirt cheap and the motor and tranny are good. I'd do it just to get a spare ATX trans.
I did a search but came up empty.
Thanks all!
Shawn
'98 Contour SE Sport v6 ATX - totaled in August of '05 '95 Mustang GT Convertible - 5-Speed.
Hello Shawn,
Did you try looking at the post(s) at the TOP of the forum ???
There is a list of materials identifying not only the difference between 4 cyl and 6 cyl CD4E transaxles,
but the differences between the years and what was changed...
Pete... 2004 Mercury Marauder 300A Black Clearcoat/Dark Charcoal LEATHER DOB 10/31/2003 DOP 1/2/2004 www.mercurymarauder.net
Originally posted by RoadRunner:
Hello Shawn,
Sure did. Here's what I see at the top of the forums:
Of the stickys, I'm assuming you are refering to the 1st one as the others do not have anything to do with an ATX. I read through it and I saw a bunch of part numbers for rebuild kits / parts etc., but not anything definative as to what changed in the model years etc. The only thing I saw close was a different 'drive chain' for the 2.0l vs the 2.5l. The TSS sensor has been hashed through all over the place but I couldn't find anything to the effect of 'the 4cly ATX will bolt right up and be happy' or even 'no it will not work, the 4 cyl ATX is a POS and besides that the bellhousing is different'.
So the question remains... is it worth pursuing a 4cyl ATX to have on hand for use on a v6 car?
I'm sorry if I totally missed the point of your response but I haven't found the information I'm looking for via a search / courtesy read of the stickeys.
Shawn
U
U
Here is the thread that I think Roadrunner was referring to.
But to put it on the table, a 4cyl ATX will not work, as a direct replacement, in place of a 6cyl. I outline a few of the reasons why in the thread above.
Phillip Jackson `98 Mystique LS 262K+ and counting... ATX rebuilt @ 151K "This storm has broken me, my only friend!" RIP Dime
Sweet! Exactly the info I was looking for.
Thanks,
Shawn
U
U
Glad that you found it informative. I guess I need to add it to the thread above.
Post is now stuck at the top of the forum.
