Last weekend I was replacing the much worn and patched rear reflector with one I got off a 1999 Contour at the junkyard. While doing this, I noticed two places where the car was cheapened that I haven't seen posted before.
Well, at least they got rid of the stupid brass inserts for the license plate mounting holes. However, the 1999 rear panel has no inserts (just threaded plastic) for the top two holes only with rubber bumpers where the bottom holes used to be. I hate when they don't give you bottom holes because the license plate rattles every time you close the trunk!
The other one involves the wiring for the license plate lights. I actually had to use the wiring from the 1998 panel as it wasn't compatible. The 1998 has sockets that the license plate wiring plugs into with tabs to hold the plugs in place. The wires themselves have foam sleeves over them, and are fused into the license plate light fixtures. The 1999 had plain wire that just ran to the fixtures and then had slip on connectors.
Not a big deal, but another case of decontenting.
You can pillage an enemy once, but a customer is an endless resource.
James Oerichbauer - PFPC Global Fund Services
Ross: 1998 E0 SVT Contour, Toreador Red, Konis, Superchip, KKM w/heat shield, SHO-shop y-pipe and rear strut brace, no res, ScotchCal, Moda Sport 16x7.5 wheels with 205/55ZR16 Dayton Dayton tires... more
Bastages!
1999 Amazon Green SVT Contour (#554/2760)
Stock SVT Duratec V6 with:
Intake- K&N filter/75mm MAF meter
Exhaust- MSDS Y-pipe/Bassani catback
Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter
179.2 FWHP at 6900 RPM
9
9
What years did they switch to the decontent for the license plate holes? Because I don't have any bottom ones either. It's particularly annoying because I had a WPI plate-cover that ONLY had bottom holes; so I had to screw that onto the license plate only!!
Matthew
98.5 Contour SE V6
It has spent 1.5 years under the wrong identity ;-)
