Posts: 240 |
so i cleaned my TB about 6000 miles ago. now my throttle is starting to stick again. what gives?
i know the previous owner and he never had trouble with it. I had the car 5000 miles and it started sticking before i cleaned it.
only mod i've done that should affect that is a K&N. maybe the new filter was over oiled? am i getting more blow by that is recirculating and gumming up the TB?
how often do y'all clean your TBs?
BTW, there is that sticker in there that says "don't clean me, special coating." what's that all about?
thanks -eric
Please: put something meaningful in your post subject! NOT "please readme!". -------------------- "your" is possessive, "you're" is the conjunction that is short for "you are", "there" is for "the dictionary is over THERE", "their" is the possessive one, and "they're" is a conjunction that is short for "they are". have a nice day :rolleyes: -------------------- Silver Frost non-E1 SVT/Contour see my registry/profile: http://contour.org/carprofile/carprofile.cgi?a=display&uid=00004623
Posts: 263 |
Alcohol is my friend Mongolian BBq S.H.
Administrator
Administrator
Posts: 702 |
Time for a PCV valve change?
Too much oil getting in the intake and gunking up the back of the TB.
Or, try a home-made oil separator to reduce oil deposits in the intake.
-Lance
Lance Kinley CEG Webmaster 95SE, "Official CEG Beater" Quaife, SVT parts, ST200 wheels, SS Y-pipe I perceive you to be a stand-up, rational individual...
Posts: 121 |
Please look in the FAQ/problems section of the website (not necessarily the forums). There is a Throttle-hang fix. I am not familiar with it, but just thought I could help point you there if you haven't seen it already.
Have you put in your $0.02 to save contour.org?? Put in what you can spare to keep the site up. Check the General Forum. ~~~~~~ David * 2k Black SVT on 17" Konig/Yokohama * MB Quart all around; Alpine 7995, DEI/Alpine amps; Dynomat
Soon to come: 19" HRE 445s under GC/Koni Setup, Custom passive-AWD kit, 2 small Sequential Turbos running low boost, Sequential 6-speed, Widebody Kit, custom black-red chameleon paint; on and on...
Posts: 240 |
i'll look into the possibility of a bad PCV. how many miles is one of those good for? i have 30k on the car.
it's not TH, although that fix is in the works...
Posts: 1,861 |
First, find out if the throttle plate really is sticking in the throttle body. When the car is cold, disconnect the throttle cable and see if the throttle plate is sticking by trying to open it by hand. Sometimes the sticking is only present with the engine running so start the car and see if the throttle is sticking by opening it by hand. If there is no sticking with the cable removed, look elsewhere for the sticking, such as the cable or throttle pedal.
Next, remove the intake tube and look inside to see if the throttle plate is actually digging into the throttle bore. If it is, and you are still in warranty, take it to the dealer and ask for it to be replaced. If the throttle plate is contacting the throttle bore, you can adjust the throttle stop just enough to keep the throttle plate from binding. Only move the throttle stop about 1/8 turn at a time until the clearance is OK. Don't move it more than a total of 1/2 turn. You will throw off the throttle position sensor setting if you go too far which will create some drivability problems.
I clean my throttle body often. Probably about every 10,000 miles, sometimes mofre often. It has been dirty enough to stick only once or twice. every time I clean it I notice an improvement in performance, especially the part throttle response.
The sticker on the throttle body that says not to clean it is because of the teflon coating on the throttle bore. The teflon coating is supposted to make it so that it never needs to be cleaned. Although the teflon coating does help to keep the gunk from sticking as bad, it still does get dirty, and should be cleaned as a matter of maintenance from time to time. Because of the teflon coating, you must be gentle when cleaning the throttle body so you don't remove the teflon. The teflon coating also makes it easier to clean.
Jim Johnson 98 SVT
Posts: 101 |
Second on the throttle stop adjustment screw!
Mine wasn't even touching, thus causing the plate to "lodge" itself shut after every opening. HOW ANNOYING that was. After adjusting, no problems!!!
***100 POSTS...WOOOOHOOOOO!!!***
Jim 98 EO CSVT #761
