As the subject suggests, I have a strange intermittent "chirping" sound coming from the front passenger side while rolling. Seems like it gets faster the faster I roll... Have no clue what this could be as it does not happen when stopped so I can take a look. Any clues?
98 E0 Silver SVT
KKM - Bassani - MSDS - BAT - ES - Unorthodox - HID - Dyna-batt - Koni - Ground Control - 17" MAS Italy Rodger - Quaife - Fidanza
"Every easy girl I have been with has been either a hosebeast or a headcase" - Pete D
H
H
Check for bird's nest in wheel. smile
stock CD on LS, cass on LX
4 wheel discs on LX only
It sounds like it may be your brakes....try applying the brake slightly after you begin roll from a stop. See if the noise gets louder, goes away or stays the same. With this check you will help eliminate some variables.
Regards,
Anastazi
Father of the Aussie Bar
anastazi.sarigiannis@aam.com
Nope, tried that Aussie... Tried to figure if its the trans too by seeing if the noise goes away by shifting to neutral, no luck. Maybe a pulley or belt?
98 E0 Silver SVT
H
H
Well since you've ruled out bird's nest, how about CV joints?
Try a little steering movement to see if that affects chirping although at this point I'm not sure you can rule out wheel bearing.
I've got the same chirping on my '99 SVT. Stepping on the brakes or turning the wheel slightly to the left makes it go away. Any thoughts on what it could be?
Brian
'99 SVT Blk/mid blue
#2414 7/30/99 (a Friday car)
'99 SE (Wife's)
Had this same symptom on an old taurus ('92). Turned out to be worn out pads and a frozen caliper pin that kept the pads from baking off fully. Not sure this is likely on your newer vehicles. Point is check the pads for anything irregular.
EDIT: oops sorry missed the post above about the brakes shocked
T-Red SVT E0 #2321 of 6535
