#59844 05/02/02 02:37 AM
E
edorfox Offline OP
E
Hi,
Anyone know what this means??
OBDII Data
Thanks...Ed
2000 Silver Frost SVT
#1625 14 Jan 2000
Dual Mode Dampener
A/C switched
K&N Dropin
Magnecor
Ed:
Did you download and install the following files from www.obd-2.com:
- Defined Ford test results file (I believe this is the file that will fix your problem)
- Enhanced Ford data file
I ran the same Test page this afternoon and got very different results. If you notice, your TID column has a lot of "Manuf Def" in them. Mine don't have that text, but other text that I believe is more specific to Fords.
I just got the software the other day and have been trying to learn it, so take what I say with the proverbial "grain of salt".
Let me know what the resolution to your problem is once you figure it out.
1996 Contour SE Sedan 4D (Royal Blue)
Duratec V6 2.5L 24-valve DOHC
Automatic
75,000 miles
No Mods (unless you call the DMD a mod)
Replaced EGR valve (gunked up), EVR (EGR VR), PCV valve, and evaporative emissions hose (cracked).
