#652698 06/03/03 06:51 AM
1
1
Just wondering if there is a double plat plug for the SVT C. than stock?
YOU LIFT YOU LOOSE!
#652699 06/03/03 11:28 AM
Use 'SEARCH' numerous discussions.
1999 Toreador Red SVT, DOB 4/22/99, 2005 Of 2760. "Many posted questions are answered by farm boys"
#652700 06/03/03 05:09 PM
Yes there is.
However unless you are running a hybrid 3L why exactly do you need one???
#652701 06/03/03 06:14 PM
even with the 3L hybrid i wouldnt say you "need" one.
ADAM NYGAARD 97 GREEN GL MTX 3L HYBRID, 3L UPPER AND LOWER INTAKES, 24# INJECTORS, RES. REMOVED, INDIGLO GAUGE FACES. 98 BLACK TAURUS SE 3.0 DURATEC
#652702 06/03/03 09:30 PM
I do.
Upping compression by over a full point is one very good reason for choosing colder spark plugs. As is running forced induction or nitrous. Basically anything that increases cylinder pressure (and thus temperature) requires a colder plug. Don't want to get pre-ignition at high RPMs because your plugs are hot enough to ignite the air/fuel charge before spark occurs - on the engine hard is a BAD time to get uncontrolled combustion.
That said, going colder without good reason will get you a set of fouled spark plugs right quick.
With the above warnings, I run APP103 plugs, which are one Autolite step colder than stock.
