Posts: 33 |
I just found out that my oil pan screw to drain the oil has been stripped and the pan itself is also stripped. I tried one of those new FRAM quick change oil plug, but the remaining threads on the pan wont hold it. Any suggestions???
Posts: 1,040 |
Although I can't refer to any by name I think there are several after market products to deal with this frequent problem. Try an auto supply store.
Posts: 3,419 |
Originally posted by horseydug: Although I can't refer to any by name I think there are several after market products to deal with this frequent problem. Try an auto supply store. Heli-coil.
Posts: 307 |
Bingo, but does Heli Coil work with liquids? I've only used it on screw holes and such that were "dry". Just asking... :p
'99 Contour SE V6 w/MTX (Black Clearcoat) '02 Dakota 4.7L V8 2WD X-Cab (Flame Red Clearcoat)
Posts: 82 |
Can't you just buy the next bigger drain plug and tap an appropriate hole?
'99 Contour SE Sport V6, 5spd, Dark Blue / Blue
Posts: 3,419 |
Well, Heli-coil sells kits to repair spark plug holes, so I imagine they seal up well enough for an oil pan.
Or, you could just drill and tap for a bigger drain plug and use whatever bigger size works, I guess.
Posts: 1,040 |
Sorry guys drilling/tapping oil pan wasn't the type of device I was suggesting, since they would create metal cuttings that would have to be removed. I was thinking of a rubber type plug that goes in and expands when tightened to seal the drain. I can picture it but can't name it, sorry.
Posts: 33 |
Thanx for the input. I went to 3 different garages and re-tapping the pan is a possibility. However, they also said that the pan might crack since ii is aluminum. I'll check out heli-coil anyway. I'm really thinking about selling the car, but I have invested a lot into it and would hate to part with it.
Posts: 1,040 |
OK checked out the device referred to in earlier post. Sold here by Canadian Tire but comes from U.S. Sold under brand name OIL-TITE a line of various oil drain plugs (replacement, oversized, self-tap, expanding rubber, etc.) Manufacturer: Motomite, Division of R&B Inc. P.O. Box 1800 Colomar, PA. 18915-1800 U.S.A.
NASDAQ stock Symbol RBIN
Sorry I can't advise re US retailer. Price should be about $5 US.
Posts: 33 |
Thanx for the info. I'll see if I can contact them for the fix. I'm still looking at parting with the car anyway. Probably later in the summer before I move out west.
