O
OCO90 Offline OP
O
Alright I got everything off the cap the brake fluid resvior and the old pads are out and i am not able to compress the caliper back into the cylinder.
I really need help
thanks
2000 svt
You shouldn't compress the caliper and push the old dirty fluid into the master cylinder.
Open the bleeder valve (relieves hydraulic pressure) and compress them and the old fluid comes out. Bleed again when done.
My name is Richard. I was a Contouraholic. NOW: '02 Mazda B3000 Dual Sport, Black BEFORE: '99 Contour SE Sport Duratec ATX Spruce Green PIAA 510's, Foglight MOD, K&N Drop-in
Front or Rear?
The rears need to be turned in, the fronts compressed.
1998 SVT Contour E1, Black (Mine) - Winter 3.0 Project 2004 Sentra SE-R SpecV (Wifes) www.SuperHawkForum.com
turned in!!! whoa.
How do you turn them in? Why are the rear pistons differant from the front? Thanks.
Originally posted by Guilty2:
turned in!!! whoa.
The rear brake caliper pistons have two small notches on the piston face. Using a pair of needle nose pliers inserted into the notches you can slowly turn the piston back into the caliper. The reason for the turning piston is to facilitate the use of a parking brake. Pulling on the parking brake turns the piston just enough to engage the rear brakes only.
'99 Black SVT Join the SVTOA
I used the needle-nose pliers to turn the piston, too. It's super-easy, but just make sure you're careful with the rubber dust boot. It can get all twisted up as you turn the piston. My advise is to use those same needle-nose pliers to *carefully* pluck out the dust boot from behind the piston. It will be easier to turn the piston. It pops back in pretty easy. But again, be *very* careful.
Old car: '98 SVT T-Red K&N air filter; Ford Focus RS shift knob. Off to be auctioned off somewhere. New car: 2003 Honda Accord DX Sedan, 5-speed.
Ahh! makes sense.
So essentially by turning the piston in or out, could I adjust the parking brake set point? Or is there yet another way?
Moderated by  Andy W._dup1
