Sounds like a wheel bearing. Since it happens when you turn left, its probably the right front bearing. Its not a hard fix if you know how to do it, but it helps to have a bearing press. I'm not savvy enough to do it myself, so when I had one go last summer I took it in. Cost me less than $150 for parts and labor, so make sure you shop around. One place wanted $250 for the same job.
