The triangles?
pop the little circle out (it will probably get mangled) then undo the screw.
Depending on the size of your tweeters, you may need to make new panels. Smaller tweeters can fit in by cutting a hole with a keyhole saw on a drill, then trimming as needed. I had to make new panels out of fiberglass.
