Originally posted by G Pappas:
Which door (front or back)?
If I remember correctly, that part (on the front door) should be fastened with a screw. There should be a small cover (about 3/8" in diameter) covering the screw that can be popped off with a small screwdriver.
If I'm not wrong, the back doors should be the same!?!
you are correct sir!
however, be careful when prying those little puppies off....you can scratch them up pretty good.
something that always works for me?
SILLY PUTTY!! Just stick some on the cover and yank! perfect every time!
