Posts: 606 |
'95 'stiqueLS 2.5L ATX
S&B / CTA intake
KEM Mag-Plus wires
1/4" TH fix
Homemade heat shield
Xenon bulbs
Fog light rewire
ATX cooler
Flowmaster 942042
Blacked-out pseudo-chrome
Posts: 808 |
Thats about the time most timing belts/chains go out from what I hear. I replaced my belt at 83,000 and water pump too. Got one with the metal impeller.
On another note, sorry about your car. I got a 95 too but I have the four. Great cars to have such big problems.
95 Mystique GS Zetec ATX: Dead - Dec 5th, 2003
94 Accord LX 2.2L MTX Non-Vtec. Few bolt ons.
02 Escape XLT 3.0 V6 ATX. This thing has the CD4E in it?! What the hell was ford thinking?
Posts: 160 |
Originally posted by Obsidian: Thats about the time most timing belts/chains go out from what I hear. I replaced my belt at 83,000 and water pump too. Got one with the metal impeller.
Timing BELTS may fail at around those mileages, but usually not chains (although it's not impossible). It may be that the chain tensioner for the right bank crapped out (a concern on early 2.5L engines, I think it was fixed in '96 & later years) and the chain is flopping around and jumped a couple of teeth on the sprockets.
There's an upgrade for the early Duratecs that changes the chain tensioner(s) configuration to one that is less prone to leak-down but it requires retrofitting later model valve timing components to the engine. Prolly not a warranty upgrade/fix either, not sure. There have been other threads here talking about cold start timing chain noises in '95 Duratecs, this failure may be related to that issue. It's also a problem in current 4.6L & 5.4L modular engines, not the failure, but the cold start-up noise.
I sure hope that PranQster didn't do major damage to his engine. All that clattering can't be a good sign.
Kurt
'95 Contour SE, MTX, Champagne
'03 EB Expedition, Med Wedgewood Blue
Posts: 29 |
If the timing chain does break, you will immediately have no power. Timing chains usually last a very long time. Timing belts will break much sooner and must be replaced as per the manufacturer. Timing chains will usually last the life of the vehicle. From your description of the problem, it does not sound like your timing chain broke. These 2.5 liter engines are interference type engines, so if your timing chain did break, you will probably also need a valve job as well. If your timing chain did break, it would be very unusual since timing chains on these cars are almost never a problem.
Posts: 606 |
I think it may well be that a chain has skipped or broken teeth off a cam... it may well be related to the startup chain noise... my car used to do that on a regular basis, then the noise went away for awhile, then recently I noticed the startup chain rattle happening again. This is not fun, but I am looking forward to the learning experience... I'm also looking forward to the opportunity to finally fix my ATX leak while dealing with this problem... gotta see how the $$ situation turns out... time to kiss a$$ to my employer and my bank
S&B / CTA intake
KEM Mag-Plus wires
1/4" TH fix
Xenon bulbs
Fog light rewire
ATX cooler
Flowmaster 942042
Posts: 834 |
dude pm me. that crap jsut happened to me and i just did my motor swap. Pm me and lets talk
HaHa You Watching me? Keep Watching
Posts: 160 |
Originally posted by PranQster: I think it may well be that a chain has skipped or broken teeth off a cam... This is not fun, but I am looking forward to the learning experience...
Man! I can think of a lot less painful ways of having a learning experience!! I just hope the racket you heard was the chain rattling around and not the valves and pistons doing the hunka-chunka
Good luck, man!!
Kurt
Posts: 606 |
I think it'll be ok... up until it stopped it was running very sluggish uphill.. parked at idle and slightly revved I could hear some rattle beneath the rear (right?) valve cover, but it was feeling normal downhill and shifting smoothly etc... couldn't tell anything was wrong until it required some torque... then it lost all power going uphill... but it did no loud clanking, no strange sounds when that happened... wouldn't start after that though it was trying... no unusual sounds while cranking either.... I think it's not operating the rear cams at all... shop is closed on weekends and the mechanic on duty could only spend about 5-10 minutes for first-impressions on Friday... he said though it wouldn't start it was turning the front cam(s) but couldn't see the rear cams but didn't think they were turning... I'm guessing he was checking the cam position through the oil fill hole. Sorry if I'm being redundant... just trying to cover all bases and provide as much info as possible. Thanks for the support  :)
S&B / CTA intake
KEM Mag-Plus wires
1/4" TH fix
Xenon bulbs
Fog light rewire
ATX cooler
Flowmaster 942042
Posts: 9,602 |
Known bad condition, making audible noises and you still drove it around a considerable amount. Are we suppose to have pity of you for doing such! COMMON SENSE people!
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 606 |
Hehe, whatever dude...you weren't there so mellow out.
Anyway I came to post that it was un unrelated problem and the sounds only had appeared to be coming from where I thought I heard them... I had the main cat go bad on me... The mechanic at the shop couldn't get the car to start yesterday, but today it started fine when it was cold... he found there was hardly any exhaust pressure. Said it was no charge, so I got him a case of beer, then I unbolted my main cat and saw broken brick material and wire etc come out... drove the car home loudly, removed the cat and gutted the thing... put it back on and all is well now. The clogged cat explains why the rasp had disappeared from the exhaust... which is now back to it's old raspy self. Better than a bad chain, huh?
S&B / CTA intake
KEM Mag-Plus wires
1/4" TH fix
Xenon bulbs
Fog light rewire
ATX cooler
Flowmaster 942042
