Well this has been happening since 88K, I'm now at 112K and it got worse recently. The engine will rev fine when there is no load on it(i.e. trans not in gear), but when you try to move somewhere it bogs down and would probably stall if i didn't feather the clutch and throttle to keep it going. THIS ONLY HAPPENS WHEN THE MOTOR IS COLD. After about 10mins or so the contour is fine. I'm not pulling any CELs or anything, and I just replaced my upstream O2 sensor that WAS pulling a CEL, hoping it would fix this too, but unfortunately it didn't. Spark plugs were changed 1000 miles ago. So I have no idea what this is.
p.s. i did search and it came back with nothing.
95 T-Red SE MTX
Eibach springs, Custom cat-back exhaust, Cross-drilled front rotors, Momo air race leather shift-knob, Kenwood head unit, Kenwood 600w amp, 2 12" Infinty's, 18" Tantrums w/ Yoko Paradas, SCA CAI
ok at idle, but bogs/almost stalls when put in gear. definitely sounds like an egr problem.
had same exact problem in my cougar (auto) and parents car as well (grand marquis). both egr's lasted about 80k miles.
-Dan
1998.5 SVT "Black and Blue" #5292
See here for MOD list.
"Washing your car to make it rain does not work."
Awesome, so how much is a new egr valve, and where is it located?
95 T-Red SE MTX
www.fordpartsonline.com
what size motor do you have?
if you have a 4 cylinder its 69.55,
and its 41.99 for the 6 cylinder.
-Dan
