go here.. its all you need...
www.jepistons.comwww.focus-central.comJE pistons sells higher CR pistons and a lil lower. Focus Central sells really low CR pistons for high boost capabilities and safety to your block (8:1 CR!!) That is what I am getting, however, I am boosting soon.
You may want the 10 or higher CR pistons from JE they are a good company. Just search under focus and it will pull right up!
Dont shave the head, buy new pistons and better piston rings. Get the SVT Focus piston rings, they are awesome! Buy a new IM, a metal one, then port and polish the head and IM and make them match. Focus Central has a new IM for sale now that will get you over 170HP, and you can slap on a bigger 65mm or 70mm TB when you have that IM ... and you can purchase up to 40lbs injectors there as well, so fuel will not be an issue.. just need to find a good fuel pump!
