Welcome to the boards!
Give us some info:
Contour or Mystique? Duratec (v6) or Zetec (4 cyl)? What conclusion made you think to clean the MAF?
Just general info...
The best cleaner to use for the MAF is the Berryman B-12 Chemtool. But like he said, make sure it is dry first. If it is indeed dirty, you should see a black/grey color build-up on the post on the V6 MAF and the wire coils on the Zetec MAF. The Chemtool seems to get the parts cleaner and dries faster without a film.
Hope that helps Rich
'04 Ecotec Cavi 140hp/150tq Fabbed intake. Header Coming, DRL's disabled, X-Drilled/slotted rotors coming....Man you really are fast. You were hauling a$$ when I passed you
RB&LB
causing problems in Huntsville
