#59412 04/26/02 11:21 PM
mikehaf Offline OP
Anyone have creaking sound in the back of the car on bumps.
#59413 04/27/02 02:38 AM
Most likely cause is the sway bar bushings are worn, or dry/dirty.
James
jpett@flash.net
StolonTour97
Riding on 17" ADR Trauma's wrapped in Falken ZE512 215/40/ZR17
#59414 04/27/02 07:52 PM
9
9
What should be used to moisten of lubricate them? -Nick
~~~~1999 Contour SE Sport~~~~
-KKM True Rev
-All Cat's fixed.
-SHO Shop Off-Road Y-pipe
-Many other Mod's done...
#59415 04/27/02 08:51 PM
well what work the best before I replaced mine was to just take them off, clean them up really good and use some high temp. grease in the opening before i put them back on. i think you'll be suprised at how dirty they are against the bar.
James
jpett@flash.net
StolonTour97
#59416 04/27/02 10:48 PM
most likely the noise is from the sway bar bushing but it may also be the parking break cable rubbing on the trailing link. I would look at this anyway becasue if the cable is mounted wrong it will where through and the parking break will start to freeze up in the winter
Son - 1995 Mystique LS Zetec 5-spd --> newest "mod" -> a girlfriend by my side
Father - 1995 Contour SE Duratec 5-spd
Mother - 1999 Contour SE Sport Duratec 5-spd
My CEG Registry
My Car
My Home Page
