#645597 05/26/03 12:45 AM
I
I
I just got my Overlays in the mail and I was wondering if any of you guys could give me some tips or tricks to make this install easier. My big question is what do I do about the needles? Do I leave them on? will they fit over or do I have to take them off? I have the gauge cluster with the tach. if that helps. Thanks alot in advance.
Jerry
97 Contour Sport V6. T-Red, KKM tru rev induction, Ford racing wires, Cooper Cobras GTH, A pillar gauge pods with ford racing gauges, Clifford Matrix alarm, painted red calipers, full bra, premium audio installed,LED's, Ford Racing seat belt pads. It's my baby!!! I love to pull up to a honda or a VW and blow their fast and furious doors off. Imports can suck my american exhaust!!!
Just wondering, but where did you get your overlays? Is that gauges only or gauges and HVAC panel?
I
I
I have been looking for reverse glow gauge overlays for along time now and I finally found them. I'm not a fan of the gauges where the whole face glows it's alittle too bright and distracting. I got them trough Pro Car Parts. The look amazing. They are just the overlays and not the HVAC panel thats what I need next anyone know where I can one of those? Also I need any helpful hints on the overlay install. thanks
Jerry
The install is really easy. The overlays from ProCarParts will slide right over the needles with no problem at all. Just secure them with something sticky (I used rubber cement, but tape will work fine).
Lemme run a search and see if I can't find the thing I wrote on how to install them...
2003 Mazda6s 3.0L MTX Webpage 2004 Mazda3s 2.3L ATX
1> Pull out the little trim pieces between the HVAC panel and the top. For a Post-98, I believe this is the piece that says "Contour" and a couple pieces on each side. For a Pre-98 this is the clock and 3 pieces of plastic. There's another above the power mirror control on the left side. They just pop out. Use a thin flat-head screwdriver with a piece of soft fabric under it just in case and gently pry them up.
2> You should uncover 3 screws. 2 on the right side of the steering wheel, one on the left side. They're just phillips heads. Unscrew those.
3> Now, look above the instrument cluster. There's 2 holes in the top of the bezel with 2 more phillips-heads deeply embedded in there. With a small phillips head you can get to them, but to me, getting them out (and back in) was the hardest part of the entire install.
4> Lower the steering wheel and the entire bezel should lift right out.
5> You should now see all sorts of steel bars, empty holes were your vents are, and right in the center is your instrument cluster. It has, I believe 5 screws in it. Unscrew those.
6> Pull the cluster forward and reach behind it and unclip the 2 wire groups that are plugged into the back of the board. Might take a little persuasion, but it's not that difficult.
7> You should now be able to freely remove the entire cluster and do with it as you please. You should probably take it inside to a nice, smooth, clean surface.
8> Now for the the part that rivals getting those damn screws out as the hardest part of the process -- prying open the cluster. Just go one clip at a time, sliding something in between the clips so they don't close right back up on you when you move to the next one. You should get the 2 halves apart in a few minutes and you'll be able to access the faces.
9> Just slide the overlays over the existing needless and glue or tape them down to the faces. Sometimes you will need to remove the needles. I can't tell you how to do that, but it does add a step that I would try to avoid if possible.
10> Once you have to overlays down and secured, simply reverse the entire process to reassemble the dash.
11> Wiring is relatively simple. It involves simply splicing the red cable from the overlay transformer into the brown cable (maybe red on some 'Tours) of your headlight relay. Ground the negative somewhere -- a bolt on the steering column is the best place.
12> Total time to complete project, even if you have no idea what you're doing (like me when I did it), maybe 1.5 - 2 hours.
Here's a version with a couple pictures, but not as many step-by-step instructions:
http://www.fordcontour.org/FCOForums/index.php?act=ST&f=32&t=1474&s=3c6b80faab045dff1f4bce63dad0b20b
And Note, as the pictoral how-to states, do NOT touch the back of the switch. You will hurt yourself.
Now he tells me
I don't think they make a reverse indiglo for the HVAC, but talk to them, tell them you'de like to start a goup buy or something.
www.ChicagoCEG.com 2006 White Grand Prix
BNoon on these Forums had some made that were really good. He might still have one or two of the HVACs left. Depending on which model you bought from ProCarParts, they match pretty well. They're pretty close to exactly the same color and even the plugs match up, so you don't have to install the other transformer thing since you'll have an extra plug because you don't have a tach to plug into there.
I installed mine a few weeks ago. I wrote up a How-To on the Pre-98 installation of those too I think somewhere on the Forums, so I can offer you that as well.
I
I
Thanks alot sigma your instructions will help out alot! I'm doing the install tomorrow so I'll post after I get them in and tell you how it went. thanks again.
Jerry
What if I my car didn't come with that "feature"?
Champagne 1995 Ford Contour LX R.I.P. - 7/11/06 V6 2.5L 24v DOHC Oversized System
hey so i have a 98 merc mystique. i was looking at the guages on ProCarParts how ever the fule and temp guages are on oppisite sides than they are on the mystique. can they be switched or does any one have any idea where i can find some #$@! glow gauges for the mystique i have been looking for ever some one help me out here
Mystique 98 ls T-red MTX B&G springs Turbendz y-pipe (running test pipe) Trubendz cat back with flowmaster muffler Costume intake with K&N filter B&M shifter Magstar wires
