#643528 05/23/03 03:21 AM
H
H
Hey everyone
Im new here and have a question about a tach I installed. It said to connect it to the negative side of the ignition coil, so I did, and it says my engine idles at about 400 RPM. and redline at 3100 RPM. I was wondering if this was right, because I have never seen any factory engine idle below about 800 RPM. I dont know if the tach is wrong or if I hooked it up wrong. If anyone could help that would be great.
Thanks
Chris
98 Contour SE - RIP 2/16/04 01 Grand Am GT - new ride -- 15.6@ 86mph stock I don't live in Houston and I don't drive a Contour anymore. Maybe I should change my name.
#643529 05/23/03 04:18 AM
hooked up or not calibrated rite.
#643530 05/23/03 06:05 AM
CEG road warrior
CEG road warrior
What tach do you have? I had to have mine recalibrated from Autometer.
#643531 05/23/03 04:41 PM
W
W
you have it hooked to where i had mine. u can't hook it there, it reads half the actual rpms. splice the wire into the wire for the tach behind the dash.
#643532 05/24/03 01:10 AM
H
H
And where might this wire be under the dash? Its and automatic and doesnt have a factory tach.
#643533 05/24/03 05:31 AM
Try looking at my tach install how-to, located here. Some people have found it useful, some have not. But it can't hurt to take a look. Good luck.
Kendall Just another mid-engined troll '93 Toyota MR2 Turbo previously '97 GL Zetec ATX
#643534 05/24/03 06:43 AM
CEG road warrior
CEG road warrior
Still might work right with it hooked up to the stock wire. You will always get a better reading from the coil. Just get the tach calibrated.
#643535 05/24/03 05:05 PM
H
H
Thanks Kendall, that helped. I finally got it working right!
Moderated by  Loco4G63
