Posts: 67 |
P1443: Evaporative Emission Control System - Vacuum System - Purge Control Solenoid or Purge Control Valve fault. The engine light came on so I got it checked and this was the code. Is there anything I should check out or clean for this????
Been shinin' like a diamond, gettin' passed as coal
Posts: 1,322 |
Evap. emissision control code could be the gasket on your gas cap, thats what is was on my friends ZX-2
1999 Toreador Red SVT, DOB 4/22/99, 2005 Of 2760.
"Many posted questions are answered by farm boys"
Posts: 67 |
Ok thanks, I'm glad it isn't something expensive like the other CEL's have been for me.
Posts: 1,960 |
Originally posted by teflon24V: P1443: Evaporative Emission Control System - Vacuum System - Purge Control Solenoid or Purge Control Valve fault. The engine light came on so I got it checked and this was the code. Is there anything I should check out or clean for this????
From the service manual........
HW7 DTC P1443: CHECK THE VOLTAGE ON THE PURGE FLOW (PF) SENSOR CIRCUIT VOLTAGE WITH ENGINE RUNNING Continuous Memory Diagnostic Trouble Code (DTC) P1443 indicates an incorrect evaporative system purge control valve flow.
Possible causes:
Obstructed, open or cracked hoses between EVAP canister purge valve and intake manifold. Damaged EVAP canister purge valve. Damaged PF sensor. Key off. Disconnect PF sensor. Check for loose pins or broken wires by pulling moderately on the PF, VPWR and PWR GND circuits at PF sensor harness connector. Repair as necessary. Reconnect PF sensor. Connect scan tool. Key on, engine running. Access EVAPPF PID. Key off.
Bless our servicemen & women overseas.
L.Cpl Ian Malone, 1st Battalion Irish Guards, R.I.P.
Posts: 67 |
Where is the EVAP canister purge valve and the PF sensor located?
Posts: 1,960 |
I'll have to dig further in either the manual or the haynes manual. Probably have an answer tomorrow.
Posts: 67 |
Thank You!  I'll check out my cd too, but I always forget where to click for everything
Posts: 1,960 |
Here's more of what I found. Damn pics don't want to cut-and-paste though. I'll see what else is on the service DVD.
Evaporative Emissions
Item Part Number Description 1 EVAP canister purge valve 2 Evaporative emission canister
The evaporative emission system consists of an evaporative emission canister and an EVAP canister purge valve. A combination of plastic pipes and rubber hoses connect the canister to the fuel tank and the EVAP canister purge valve to the intake manifold.
In addition, the evaporative emission system uses a canister vent solenoid and a fuel tank pressure sensor which are used during the engine management system on board diagnostic routines. Refer to the Powertrain Control/Emissions Diagnosis (PC/ED) Manual for further information.
When the EVAP canister purge valve is closed, the fuel tank is vented into the EVAP canister through the fuel vapor vent valves. The EVAP canister absorbs the fuel vapor and prevents the release of hydrocarbons into the atmosphere. When the EVAP canister purge valve is opened, the EVAP canister is exposed to the intake manifold vacuum and the fuel vapor deposits are drawn into the manifold where they mix with the incoming air/fuel charge.
The evaporative emission system is controlled by the powertrain control module according to calibrated data tables.
Evaporative Emission Canister Purge Valve Removal
Vehicles with 2.0L engine
Remove the air cleaner outlet tube. For additional information, refer to Section 303-12A . Remove the intake air resonator.
Vehicles with 2.5L engine
Remove the ignition coil. For additional information, refer to Section 303-07B . All Vehicles
Disconnect the EVAP canister purge valve electrical connector.
Remove the EVAP canister purge valve retaining nuts.
Disconnect the vacuum hose from the EVAP canister purge valve.
Disconnect the vapor tubes and remove the EVAP canister purge valve.
Installation
To install, reverse the removal procedure.
