I'm not sure what you mean by 'dual stage TB' but I thing your referrring to the secondary ports on the lower intake manifold. These typically open up around 3800RPM or so and can be checked by operating the throttle (on the TB
) by hand and observing the linkage as the engine revs climb above 3800. The IMRC module is a common problem component but it could be stuck linkage due to a gunked up LIM. The IMRC is located under the plastic cover on the front of the engine. (Covering the valve cover.) Follow the cable to the LIM and secondary linkage...
Check
this link out.
EDIT: Welcome to CEG! If you don't get a ton of advise on this here, try searching for 'secondary' or 'IMRC' in this or the duratec performance forum.
