#59086 04/23/02 09:57 PM
Y
Y
I have had this pretty damn annoying problem with my svt where in 1st and 2nd gears (rarely 3rd) when I press on the gas or let off, the car jerks and makes loud clunking noises. It even happens when I only feather the gas pedal.It feels like the engine is moving around, so I am guessing its the motor mount inserts. I have decided to buy new energy suspension ones. How many should I get? Should I just get however many (3 or 4 I'm guessing) of the exact same type, like the ones that cost around $18.00 from spmotorsports or cta? One last thing, what's the install like, should I have a mechanic do it for me? Thanks.
1998 black Contour SVT E0
-KKM Intake
-Magnecor 8.5 mm spark plug wires
-Bosch +4 platinum spark plugs
-B&M Short Shifter
-SPARCO front strut tower bar
-17x7 Rage 5.0's with Nitto NT450's
(215/45-17)
-24mm Aussie rear sway bar
#59087 04/23/02 10:21 PM
It could be the front lower control arms. There are rubber bushings in them that get worn out over time. I have the same symptoms and the control arms are a known problem on my car. It's the entire subframe moving around. I already checked my engine mounts/roll restrictors and they are fine.
Only problem, there is no way to upgrade them if you have the horizontal style like me. You can buy OEM, get a set from BAT, or wait for Haines Motorsports to come out with upgraded arms. If you have the vertical style, then HMS already can sell you a set with upgraded poly bushings.
#59088 04/23/02 10:34 PM
Y
Y
Would it be wise to replace the front lower control arms and the motor mounts, just to make sure? Can you get the front lower control arms through somebody like Bill Jenkins (I hate my dealership)?
-KKM Intake
-B&M Short Shifter
(215/45-17)
#59089 04/24/02 02:48 AM
Bill Jenkins won't be able to get parts 2 months iirc because he's in the process of moving...check out ford parts online for new A-Arms/bushings(yes you have to buy the whole thing)
I can tell you right now it IS your A-Arm bushings. I have the same problem which I just found out NO THANKS TO MY DEALERSHIP! Jack your car up and wedge a prybar so that you can push the A - Arm forward...you'll be REALLY surprised at what your wheel does!
Originally posted by 99SESPORT:
First off, if somebody is grabbing your nuts, your gonna do everything you can to get him off...
And sitting there telling him politely
"Please let go of my nuts, sir?"
#59090 04/24/02 03:10 AM
- Pete - 00 SVT SF/MB - 1522/2150 - DOB 1/12/00
92% says your group-NOT HOT
85% says your either wrong or BLIND
Blackhawk Down did NOT suck
you know who you are.....
#59091 04/24/02 03:19 AM
Pictured on that page is the "vertical style" lower front arms. Lucky me I have the expensive horizontal style. mad
#59092 04/24/02 05:50 AM
So, HMS, Mr. Haines, where can we get the upgraded bushings?
By the way, whats it going to cost for a Quaife installation?
Jim
98 EO CSVT #761
#59093 04/25/02 01:03 AM
are those prices in US$??
here's the problem i have on my contour. When i'm driving around 60km/h i hear some noise coming out of my front left wheel. and if i steer to the right just a little bit, the noise is louder and sounds like something is rubbing off my tire. I looked in there, but there's nothing. And if i'm at low speed, like 20-30km/h, it seems that i dont hear that noise. Another thing, a totally different noise when i'm going off the ramp for example, and ONLY when steering to right.
sorry if i didn't explain the problem very well, hopefully somebody here had some kind of a same problem and can share it.
Thanks a lot!
96 Ford Contour LX
#59094 04/25/02 03:29 AM
Might as well check the sway bar for movement. Reach behind the front wheel and push/pull on the sway bar to see if it is loose or moves side to side. The sway bar bushings wear out and allow the bar to slide over and rub the inside of the tire in some cases.
Scott
#59095 04/25/02 05:14 AM
i have this too sometimes on my car. i'm having the people at ford look at it tomorrow (gotta love warranties smile )
Black 98 Contour SE Zetec ATX
5% Charcoal-black tint (tint on exterior and interior)
Knauberized on 5-05-02
