Page 2 of 2 1 2
#640697 05/21/03 03:48 PM
coud your secondaries have locked?
95 GL MTX Zetec, Carbon Fiber hood: *neoprene seat covers *new SVT rear bumper *Proud Owner of 1962 Chevy Corvette 427
#640698 05/21/03 03:55 PM
That I don't know but thanks for bringing it to my attention. I was told that after the Cats are replaced they'll test the car again to check for any further problems.
#640699 05/21/03 04:03 PM
W
W
Hey maybe it's something really easy and they just missed it. In anycase you just got some new cats!
1999 Contour SE Duratec ATX My feet and the Stra�Ÿenbahn http://www.tempo-topaz-performance.com/topazsho/ the coolest Topaz ever! To bad it's not mine
#640700 05/21/03 07:48 PM
clogged cats was my first thought, but I've been burned by them before. If the dealer replaces the main cat, make sure they check and or replace the pre-cats because they are probably the cause. The pre-cats crumble and cause the main cat to clog up. They will continue to crumble and cause problems unless replaced or gutted. Once your past 80K, they won't touch it on warranty.
#640701 05/21/03 11:28 PM
U
U
True! I second that.
Phillip Jackson `98 Mystique LS 262K+ and counting... ATX rebuilt @ 151K "This storm has broken me, my only friend!" RIP Dime
#640702 05/22/03 01:38 AM
2
Before spending all that time and money on the exhaust make sure the ignition is up to par. Faulty coil pack will put a lot of gremlins under the hood. Had my share of HV bugs. Then there are mystery vacuum leaks. One car I had would act up going up hill in second gear. Later found it was a vacuum line with a crack in it. It would bump the firewall when the engine torqued up and open up enough to upset the fuel system mixture.
Fuel Pump. Had mine replaced under factory warranty about 3 months after I got the car.
99 Blk SE Sport 2.5 CD4E Euro Focus SVT Wheels 5 % tint Mesh Grilles w/indiglo ford KKM intake filter FMS 9mm wires Superchip Signal mirrors Fog lamp mod Dingless A6 sidemarkers Duals SVT springs/struts
Page 2 of 2 1 2
