#59040 04/22/02 10:29 PM
I think my 2nd gear cyncros are going bad. I've driven two contours (not mine) that had very bad syncros problems (both 2nd and 3rd were terrible), and I'm worried about mine going bad now. I get a very slight grind going into 2nd when the car is cold. I know its really expensive to fix if they go out, so is there anything I can do to be easy on it? I've been avoiding 2nd till the car warms up.
99 SE Sport MTX SilverFrost Duratec
#59041 04/22/02 10:35 PM
9
9
You probably should not skip gears, I would imagine that it would wear down the 3rd gear synchro faster, it would probably have to do alot more "syncronizing" to get the gears to come together. Have you tried the trannie coctail yet? if this is really happening when its cold, the trannie coctail would probably help. I would not be skipping past 2nd gear though... -Nick
~~~~1999 Contour SE Sport~~~~
-KKM True Rev
-All Cat's fixed.
-SHO Shop Off-Road Y-pipe
-Many other Mod's done...
#59042 04/22/02 11:10 PM
Slow up shifts and double de-clutch on down shifts will give them a bit more life...use friction mod if its no in the trans now and ..save up for a rebuild!..
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
#59043 04/23/02 01:48 AM
could try cyncro mesh just a thought
#59044 04/23/02 01:52 AM
funny...I have a 4th gear grind and it's more noticeable now with the tranny cocktail done.
Terry is right though, slow upshifts (painful but necessary when racing frown ). I can't speak for double clutching on downshifts, It doesn't grind then. After SZ i think I will take it in for some "warranty" work [[wink wink]]
1999 Silver Frost SVT
#609 of 2760
Born on 12/3/98
KKM Intake
Removed Resonator
35% Window Tint all around
Tinted Tail Lights
ElKy Mesh Grilles
HID
Dyno'ed at 175.3HP/155.5TQ
#59045 04/23/02 03:05 AM
Thank you so much for that very helpful input. :rolleyes:
Terry- Thanks for the advice. I'm looking into that friction mod. Any tips on it?
#59046 04/23/02 11:04 AM
If the syncros are 'on the way out' use dino dextron III and the friction mod Vs synth ATF,not so good for cold shifting but should help out the syncros...
V6 MTX
