Late last summer I was having issues w/ my A/C system and eventually found a rubber strip of hose that had a cut. I couldn't tell you which hose it is - only that it's on the passenger side (Hi pressure). I kind of put it off during the winter because I didn't need my A/C and there's no need to run the defroster here in Phoenix.
Yesterday, I decided to turn on the A/C just to see how bad the engine load would be when it cycled. Well, it never did! It used to cycle on/off every ten seconds or so but the compressor never cycled yesterday. I even got under the car and watched the pulley and nothing.
Here's my question: If the compressor cycles over and over when the system is low, is it possible that after evacuating the system over a period of months the compressor won't come on because of the complete absence of freon? Or do you think it's hosed? I've heard compressors can fail when ran w/ little or no freon in the system, but mine wasn't ran at all over the winter period.
I talked to Ford last year when I noticed the line was cut because it was about a month after they replaced the waterpump (same side of the engine bay). I wondered if it was damaged during that repair. They told me it wouldn't be covered under warranty, so I put it off until I could have it fixed, but never got around to it.
I haven't checked all the fuses yet, either. I just wanted to gather opinions and see how many people think I'll end up eating a compressor because I waited too long to repair this darn hose.
